      0WR7-00C
      Setting Up the Connection Using WPS Push Button Mode
      If your wireless router supports the WPS (Wi-Fi Protected Setup) Push Button mode, you can easily set up a connection with the WPS button on the router.
        <Preferences>  <Network>  <Wireless LAN>  <Wireless LAN Settings>  <WPS Push Button Mode>  press and hold the WPS button on the wireless router
      When the wireless LAN router is detected and the configuration is complete, the screen <Connected.> will be displayed.
      Depending on the networking device, you may need to press and hold the WPS button for 2 seconds or longer. See the instruction manuals for your networking device for help.
      If the wireless router is set to use WEP authentication, you may not be able to set up connection using WPS.
