      0WR7-08W
      Printing Files in Other Devices
      You can use the machine to directly print files saved in the Advanced Box of another Canon multifunction printer or in a Windows server.
      1
      Press <Access Stored Files> on the Main Menu. <Main Menu> Screen
      2
      Press <Network>.
      3
      Select the device you want to access.
      For information on the items on the screen and instructions on how to use them, see Working with Files and Folders in Other Devices.
      4
      Select a file and press <Print>.
      If you select PDF or XPS files, proceed to step 6.
      5
      Select the paper source and press <OK>.
      6
      Enter the number of prints using the numeric keys.
      If you select multiple files in step 4, press <Change No. of Copies> and enter the number of prints.
      7
      Specify the print settings as necessary.
      NOTE:
      To print a PDF file with a password, press <Options>  <Password to Open Doc.>  <Encryption Password> or <Policy Password>, enter the password, and press <OK>. To print PDF files that forbid printing, or print PDF files that only allow low-resolution printing in high resolution, enter the specified password.
      8
      Press <Start Printing>.
      Printing starts.
      To cancel printing, press <Cancel>  <Yes>.
