1
Select a file and press <Edit File>
2
Enter a file name and press <OK>.
1
Select a file and press <Display Image>.
2
After checking the preview image, press <Back>.
1
Select a file and press <Details>.
2
After checking the detailed information, press <OK>.
1
2
Press <Yes>.
1
Set the document. Placing Documents
2
Press <Edit File>
3
Specify the scan settings as necessary and press
![]() For scan settings, see Setting Screen and Operations for Scanning to Save.
1
Press <Folder Operations>.
2
Press <Create Folder>.
3
Enter a folder name and press <OK>.
4
Press <OK>.
1
Display a folder whose name you want to change and press <Folder Operations>.
2
Select a folder and press <Details>.
3
Press <Rename Folder>.
4
5
Press <OK>.
1
Display a folder whose information you want to check and press <Folder Operations>.
2
3
1
Display a folder to delete and press <Folder Operations>.
2
Select a folder and press <Delete>
