      0WR7-0AA
      Configuring the Network Security Settings
      Authorized users may incur unanticipated losses from attacks by malicious third parties, such as sniffing, spoofing, and tampering of data as it flows over a network. To protect your important and valuable information from these attacks, the machine supports the following features to enhance security and secrecy.
      Firewall Settings
      Unauthorized access by third parties, as well as network attacks and breaches, can be reduced by only allowing communication with devices that have a specific IP address. Restricting Communication by Using Firewalls
      Proxy Settings
      You can provide greater security by using a proxy server for connections outside the network, such as when browsing websites. Setting a Proxy
      TLS Encrypted Communication
      TLS is a protocol for encryption for data sent over a network and is often used for communication via a Web browser or an e-mail application. TLS enables secure network communication when accessing the machine in a variety of situations, such as when using the Remote UI or device information distribution. Configuring the Key and Certificate for TLS
      IPSec Communication
      While TLS only encrypts data used on a specific application, such as a Web browser or an e-mail application, IPSec encrypts the whole (or payloads of) IP packets. This enables IPSec to offer a more versatile security system than TLS. Configuring the IPSec Settings
      IEEE 802.1X Authentication
      If a device tries to connect and start communicating on an 802.1X network, the device must go through user authentication in order to prove that the connection is made by an authorized user. Authentication information is sent to and checked by a RADIUS server, which permits or rejects communication to the network depending on the authentication result. If authentication fails, a LAN switch (or an access point) blocks access from the outside of the network. The machine can connect to an 802.1X network as a client device. Configuring the IEEE 802.1X Authentication Settings
