When scanning documents that are smaller than the scanning size, frame lines of the documents may appear in the scanned image. When scanning a thick book, dark borders may appear. This function enables you to erase these frame lines and dark borders. You can also erase punch holes in the documents.
Place the document with punch holes on the platen glass. Placing in the feeder may result in damage.
1
Press <Erase Original Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the document you check, press <Change> to select the size.
2
Enter the width of the frame to erase.
1
Press <Erase Book Frame> and check <Original Size>.
![]() If the size displayed in <Original Size> is different from the size of the book you check, press <Change> to select the size.
2
Press <Center> or <Sides> and enter each erasing width.
1
Press <Erase Binding> and select the punch hole location.
2
Enter the erasing width.
