Discarding Punch Waste (Staple Finisher-V1/Booklet Finisher-V1)
Follow the procedure described in this section to discard punch waste from the 2/3 Hole Puncher Unit-A1/2/4 Hole Puncher Unit-A1 that is installed in the optional Staple Finisher-V1/Booklet Finisher-V1.
1
Open the front cover of the finisher.
2
Pull out the punch waste tray.
Hold the punch waste tray handle and gently pull it toward you.
Pull it out completely, supporting it with your hand.
3
Discard the punch waste.
4
Return the punch waste tray to its original position.
Make sure to insert the punch waste tray as far as it will go.
5
Close the front cover of the finisher.
