1
Confirm that the screen to insert a control card is displayed.
2
Confirm the direction of the control card and insert it into the card slot.
3
Confirm that the Main Menu is displayed. <Main Menu> Screen
1
Remove the control card from the card slot.
2
Confirm that the screen to set a control card is displayed.
If you set the Server Authentication user authentication system of User Authentication as the login service (including when performing Server Authentication with the 'Server Authentication + Local Device Authentication' user authentication system), you cannot use the Copy Card Reader-F1. Managing Users
If the Main Menu screen does not appear when the control card is inserted, check if the control card is inserted in the correct direction and that the control card is not damaged or prohibited from use.
