Regularly clean the exterior of the machine to keep it in good condition.
1
Turn OFF the machine, and unplug the power cord from the AC power outlet.
Turning OFF the Machine
IMPORTANT:
Check the machine's operation status before turning it OFF. You can turn OFF the machine while a process is active, but a problem may occur, which may cause you to lose or damage data.
2
Clean the exterior of the machine.
Soak a soft cloth in water or mild detergent diluted with water, wring it tightly, and use it to wipe the unit clean.
Wait until the unit has dried completely before proceeding to the next step.
3
Reconnect the power cord and turn ON the machine.
Turning ON the Machine
