1
Press <Register>.
2
Enter the necessary information.
<Server Name>
Enter a name for the LDAP server.
<Server Address>
Enter the IP address or host name of the LDAP server using alphanumeric characters (Example: "ldap.example.com").
IMPORTANT:
<Server Address> and DNS
To prevent errors, pay attention to the following when a destination search is carried out from the machine to the LDAP server.
When entering the IP address, check if the usable DNS server supports only forward lookup. When the DNS server supports forward lookup only, press <Do Not Use> or <Use> in <Authentication Information> in step 4. When selecting <Use (Security Auth.)>, confirm that the DNS server supports reverse lookup.
<Position to Start Search>
Specify where to start searching in the directory tree of the LDAP server.
For LDAPv3, you can skip the setting because the machine retrieves automatically the server’s setting. For LDAPv2, always specify the point.
NOTE:
Entering the format of <Position to Start Search>
When you use Windows Server 2003 R2 with Active Directory, Windows Server 2008 with Active Directory, or Windows Server 2012 with Active Directory, enter the domain name of the Active Directory in units of strings divided by a dot ".". Add "DC=" for each unit and separate them with commas ",".
Example: When the domain name is "john.example.com", enter "DC=john,DC=example,DC=com". When you use Lotus Notes Domino R7 or later, enter the directory tree node identification name (dn) like "cn=user1,ou=team1,ou=salesdept,o=canon".
<Use TLS>
To encode the communication to/from the LDAP server using TLS, press <On>.
<Port Number>
Enter the port number used when communicating to/from the LDAP server.
<Max Addresses to Search>
Specify how many destinations can be searched.
<Search Timeout>
Specify in seconds how long the search can continue.
3
Press <Next>.
1
Press <Use> in <Authentication Information>.
2
Enter the user name and the password and carry out the necessary settings.
<User Name>
Enter the user name of the machine registered on the LDAP server.
NOTE:
Entering the format of the user name
When you use Windows Server 2003 R2 with Active Directory, Windows Server 2008 with Active Directory, or Windows Server 2012 with Active Directory, enter in the format of "(Windows domain name)\(Windows user name)".
Example: When the Windows domain name is "example" and Windows user name is "user1", enter "example\user1". When you use Lotus Notes Domino R7 or later, enter the authenticated user identification name (dn) like "cn=user1,ou=team1,ou=salesdept,o=canon".
<Password>
Enter the password registered on the LDAP server. When the password is entered, <Confirm> is displayed for confirmation. Enter the password again.
<Display Authentication Screen When Searching>
When searching destinations, to display the user name and password entry screen, press <On>.
<LDAP Server Version and Character Code>
Select a combination of the LDAP version of the server and character code.
3
Press <OK>.
1
Press <Use (Security Auth.)> in <Authentication Information>.
2
<User Name>
Enter the username of the machine registered in the LDAP server (Example:"user1").
<Password>
<Domain Name>
Enter the domain name of the machine.
3
Press <OK>.
1
Press <Do Not Use> in <Authentication Information>.
2
Select the combination of the LDAP version and the character code of the server.
3
Press <OK>.
