The User Authentication login service performs personal authentication based on the information registered for each user, enabling you to limit the users who can access the machine. User information registration (authentication) can be performed on this machine and on an external server. You can configure the authentication system to use only this machine as the authentication device, or you can additionally specify an Active Directory or LDAP authentication server on the network as an authentication device to utilize the existing user information registered on the server (). Administrators can also specify which functions are available to each individual user, such as "user A is prohibited from making copies" or "user B is allowed to use all machine functions." For the user login method, you can enter authentication information, select a user, use an IC card, or use a mobile device Bluetooth function (). Before configuring the user authentication settings, decide the authentication device and login method.
[Authentication Management].
[OK].
[User Name:] / [Password:] / [Confirm:]
[PIN:] / [Confirm:]
[Displayed As:]
[E-Mail Address]
[Department ID]
[Select Role to Set:]|
[Administrator]
Allows access to all machine operations.
[GeneralUser]
Allows general user privileges.
[DeviceAdmin]
Allows operations that are available to general users, along with the ability to change settings related to basic functions such as copying, printing, sending, and receiving.
[NetworkAdmin]
Allows operations that are available to general users, along with the ability to change network-related settings.
[ID to Register for IC Card 1:] / [ID to Register for IC Card 2:] / [Verification Value:]
[Set expiration for the user account]
[Disable the user account]
[User Group Association]
Configuring settings via the control panelYou can also register user information by pressing
<Management Settings> <User Management> <Authentication Management> <Register/Edit Authentication User>. <Register/Edit Authentication User>Creating user groupsAddress Lists in the Address Book can be shared between users who are registered in a user group. Registering User Groups
TIPS
Check for unregistered Department IDsIf you click [Check Unregistered Department ID...] on the screen displayed in step 4, you can find out Department IDs that are not registered in the machine by checking Department IDs assigned to the users against Department IDs registered in the machine.
