For information on the paper sizes that can be used for Staple Free, see Specifications.
Depending on the usage environment and paper type, the crimped part may be split easily.
Booklet Finisher-AA
Staple Finisher-AA
Tray A
Staple Button
<Time Until Stapling Starts in Stapler Mode>
Buffer Pass Unit
Front cover (upper)
Slit
Front cover (lower) (Booklet Finisher-AA only)
Booklet tray (Booklet Finisher-AA only)
Tray B
Booklet Finisher-AA
Staple Finisher-AA
Saddle stitcher unit (Booklet Finisher-AA only)
Punch waste tray (2/3 Hole Puncher Unit-A)
1
Place the desired bundle of paper into the slit in the staple finisher or booklet finisher.
Insert the corner of the paper bundle where you want it stapled straight into the slit, with the front side of the paper facing down.
When the paper bundle is sensed, the staple button starts to blink and automatic stapling is performed.
![]() ![]() You can set the time in seconds to elapse before stapling is executed. <Time Until Stapling Starts in Stapler Mode>
You can perform stapling without waiting for the specified stapling start time to come. While holding the paper bundle with one of your hands, use the other hand to press the staple button.
2
Pull out the paper bundle.
Wait for the staple button to turn off, and then pull out the paper bundle.
You cannot perform manual stapling while outputting of printed paper continues.
For information on the paper sizes that can be used for Staple, Saddle Stitch, Hole Punch, and Saddle Fold, see Specifications.
To replace the staple cartridge of the stapler unit or saddle stitcher unit, see Replenishing the Staples (Optional).
For how to clear a paper jam or a staple jam, see Clearing Paper Jams and Clearing Staple Jams (Optional).
The maximum number of bindable sheets may not be possible, depending on the paper type. In this case, change the paper type, or reduce the number of sheets to bind.
Collate and groupIf you select <Offset> in combination with the collate or group function, each printout group is shifted.
Once an output tray has reached its stacking limit, subsequent prints are automatically delivered to the next available tray. If all of the available trays have reached their stacking limits, printing stops. Remove all of the output paper from the trays to resume printing.
StaplersWhen you are using the Staple mode, do not remove the stack of paper from the output tray during the job. Remove the stack of paper when the job has been completed.
If the message "Load staples into the stapler unit." appears, staples are running out. To proceed, replace the staple case.
If a tray reaches the lowest position limit, printing stops temporarily. Remove all of the output paper from the tray to resume printing.
Saddle stitchThe accuracy of folds may vary depending on the paper type and the number of sheets.
TIPS
If you install the "2/3 Hole Puncher Unit-A" in the "Staple Finisher-AA" or "Booklet Finisher-AA," you can punch holes in your printouts.
