Paper Sizes
Max: 12 5/8" x 18" (320 x 457.2 mm)
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)
Paper Weight
14 lb bond to 110 lb cover (52 to 300 g/m²)
Paper Type
All the paper that can be fed
Capacity Per Tray*1
Upper Tray (Tray B)
No finishing set, Collate, and Group mode:
LTR, STMT, STMTR, EXEC, A4, B5, A5, A5R, and 16K: 100 sheets or 3/8" (10.4 mm) in height
11" x 17", LGL, LTR, 320 x 450 mm (SRA3), 305 x 457 mm, A3, B4, A4R, B5R, 8K, and 16KR: 50 sheets or 1/4" (5.2 mm) in height
Lower Tray (Tray A)
No finishing set, Collte, and Group mode:
LTR, STMT, STMTR, EXEC, A4, B5, A5, A5R, and 16K: 500 sheets (or 2 1/8" (52 mm) in height)
11" x 17", LGL, LTR, 320 x 450 mm (SRA3), 305 x 457 mm, A3, B4, A4R, B5R, 8K, and 16KR: 250 sheets or height 1" (26 mm)
With different paper sizes: 250 sheets or height 1" (26 mm)
Collate + Offset and Group + Offset mode:
A4, B5, LTR, EXEC, and 16K: 500 sheets (or 2 1/8" (52 mm) in height)
A3, B4, A4R, B5R, 11" x 17", LGL, LTRR, 8K, and 16KR: 250 sheets or height 1" (26 mm)
Staple (Corner/Double) mode:
A4, B5, LTR, EXEC, and 16K: 30 sets or height 2 1/8" (52 mm)
A3, B4, A4R, 11" x 17", LGL, LTRR, and 8K: 30 sets or height 1" (26 mm)
Staple (Staple-Free) mode:
A4, B5, LTR, and 16K: 30 sets or height 2 1/8" (52 mm)
A3, B4, 11" x 17", and 8K: 30 sets or height 1" (26 mm)
Staple
Max. Stapling Capacity*2
Staple (Corner/Double):
11" x 17", LGL, LTRR, A3, B4, A4R, and 8K:
30 sheets (14 to 24 lb bond (52 to 90 g/m2)) 20 sheets (25 to 28 lb bond (91 to 105 g/m2)) 2 sheets (29 lb bond to 95 lb cover (106 to 256 g/m2)) 11" x 17", LGL, LTRR, A3, B4, A4R, and 8K:
30 sheets (14 to 24 lb bond (52 to 90 g/m2)) 20 sheets (25 to 28 lb bond (91 to 105 g/m2)) 2 sheets (29 lb bond to 95 lb cover (106 to 256 g/m2)) Staple (Staple-Free):
11" x 17", LTR, A3, B4, A4, B5, 8K, and 16K:
5 sheets (14 to 17 lb bond (52 to 64 g/m2)) 4 sheets (18 to 21 lb bond (65 to 81 g/m2)) 3 sheets (22 to 28 lb bond (82 to 105 g/m2)) Manual Staple:
All sizes:
50 sheets (14 lb bond (52 g/m2)) 45 sheets (17 lb bond (64 g/m2)) 40 sheets (20 lb bond (80 g/m2)) |
Dimensions (W x D x H)
18 5/8" x 20 5/8" x 7 1/8" (472 x 525 x 182 mm)
Weight
Approximately 17.6 lb (8 kg)
Installation Space Including the Main Unit
(W x D)
43 3/4" x 44 1/4" (1,110 x 1,123 mm) (when the auxiliary tray is extended)
