You cannot use the machine while unnecessary data is being deleted. After data deletion is complete, it may take some time before the machine is ready to scan originals.
The machine's processing capacity may decrease when data is deleted.
Initialize the data and settings to delete data such as files stored in the Mail Box, Address Book information, or copy and print log information. Initializing All Data/Settings
1
Press <Timing of Deletion>.
2
Select the deletion timing, and press <OK>.
Select <During Job> to delete data immediately after each process is complete, or select <After Job> to wait until all operations are complete and delete all unnecessary data together.
1
Press <Overwrite Method for Deletion Mode>.
2
Select the deletion method, and press <OK>.
To prevent the leakage of sensitive data when replacing or disposing of the hard disk, overwrite it with 0 (null) data, random data, or a fixed value (such as 0xff). Select the overwrite method and the number of times to overwrite, based on the information security policy requirements of your environment.
![]() ![]() Data is overwritten once with 0 (null) data.
![]() Data is overwritten once or three times with random data.
![]() Data is overwritten three times. The first time is with a fixed value, the second is with a complement of the fixed value, and the third is with random data.
3
Press
