Setting a Proxy
1A94-09S
You can set a proxy to handle communication in place of the machine, and use it when connecting to devices outside the network, such as when browsing websites. Security is enhanced when using a proxy, because the machine does not directly access resources outside the network. Administrator or NetworkAdmin privileges are required in order to configure these settings.
1
Press .
2
Press <Preferences>  <Network>  <TCP/IP Settings>  <Proxy Settings>.
3
Set <Use Proxy> to <On>, configure the necessary settings, and press <OK>.
<Server Address>
Enter the address of the proxy server to use. Specify the IP address or host name depending on your environment.
<Port Number>
Enter the port number of the proxy server to use.
<Use Proxy within Same Domain>
Select <On> if you want to use the proxy server even when communicating with devices in the same domain.
<Set Authentication>
To use the proxy server authentication function, press this and configure the authentication information. On the screen that is displayed, press <On>, enter the user name and password to use for proxy authentication, and press <OK>.
4
Press     <Apply Set. Changes>  <Yes>.
imageRUNNER ADVANCE C355iF / C255iF
User's Guide
USRMA-1009-012017-02Copyright CANON INC. 2017
