| User's Guide | |
Open the feeder cover.
If an original is jammed, gently pull it out in the direction of the arrow.
![]() If you cannot remove the jammed original, proceed to the next step without forcibly removing it.
Lift the original supply tray.
Return the original supply tray back into position.
Lift up the feeder, and check the position indicated by
