When SNMP management software is usable, you can set, monitor, and control the machine through a computer. For details, see your software's instruction manuals.
<Network>
<SNMP Settings>.|
1
Press <On> in <Use SNMPv1>.
If you don't use SNMPv1, press <Off>.
2
Press <Set Dedicated Community>, <Set Community Name 1> or <Set Community Name 2>.
The exclusive community is a community (group) prepared for managers using Canon software such as imageWARE Enterprise Management Console. To use the exclusive community, press <Set Dedicated Community>. To specify a general community, press <Set Community Name 1> or <Set Community Name 2>.
3
Set the community.
![]() <Dedicated Community>/<Community Name 1>/<Community Name 2>To use the selected community, press <On>. When you don't want to use the community, press <Off>.
<MIB Access Permission>For each community, select MIB access privileges from <Read/Write> or <Read Only>.
<Community Name>Enter a community name that you belong to using alphanumeric characters. If you select <Set Dedicated Community>, you cannot set an exclusive community name.
4
Press <OK>.
1
Press <On> in <Use SNMPv3>.
If you don't use SNMPv3, press <Off>.
2
Press <Administrator Settings>.
3
Specify the necessary settings, and press <OK>.
![]() <Use Administrator>If you use Administrator, set to <On>.
<Encryption Password>If you use a password which is different from the authentication, deselect <Use Same Password as for Authentication>, press <Encryption Password>, and enter the password.
![]() If "Administrator" is disabled, you cannot set <Administrator Settings> (the setting of <Use Administrator> is fixed to <Off>).
4
Press <User Settings>
<Register>. |
5
Enter the necessary information.
![]() <User Name>Enter a user name using alphanumeric characters.
![]() You cannot use the characters "Administrator" for a user name to register. If you want to use the characters "Administrator," you need to set <Use Administrator> to <Off> under <Administrator Settings>.
<MIB Access Permission>Select MIB access privileges from <Read/Write> or <Read Only>.
<Security Settings>Set a combination of authentication and encoding. Select <Auth. Yes/Encrypt. Yes>, <Auth. Yes/Encrypt. No>, or <Auth. No/Encrypt. No>.
<Authentication Algorithm>Select <MD5> or <SHA1> according to your environment.
<Authentication Password>Enter a password to use for authentication. When the password is entered, <Confirm> is displayed for confirmation. Enter the password again.
<Encryption Algorithm>Select <DES> or <AES> according to your environment.
<Encryption Password>Enter a password to use for encoding. When the password is entered, <Confirm> is displayed for confirmation. Enter the password again.
6
Press <OK>
<OK>. |
7
Press <OK>.
<Apply Set. Changes>
<Yes>.
When using SNMPv1 and SNMPv3 in combination, it is recommended to set MIB access privileges for SNMPv1 to <Read Only>. If you set <Read/Write>, almost all of the machine's operations become practicable and the strong security functions of SNMPv3 will not be effective. Access privileges to MIB can be set in either SNMPv1 or SNMPv3. In SNMPv3, you can set them for each user.
