Making Ethernet Settings
Ethernet is a standard that stipulates communication methods within a LAN. Normally, the communication system (half-duplex/full-duplex) and Ethernet type (1000BASE-T/100BASE-TX/10BASE-T) can be set automatically. You can set them separately by switching the setting to manual operation. Register the settings as necessary.
1
Press .
2
Press <Preferences>  <Network>  <Ethernet Driver Settings>.
3
Make Ethernet settings.
Normally, press <On> in <Auto Detect>. The communication system and Ethernet type are detected and automatically configured.
Making Ethernet settings manually
1
Press <Off> in <Auto Detect>.
2
Select the communication system.
 <Half Duplex>
Carry out send/receive functions alternately. Select this when the connected router is set for half-duplex communication.
 <Full Duplex>
Carry out send/receive functions at the same time. Select this as a general rule.
3
Select the Ethernet type.
Select <10BASE-T>, <100BASE-TX>, or <1000BASE-T> in <Ethernet Type>.
4
Press <OK>.
5
Press     <Apply Set. Changes>  <Yes>.
1A94-00U
