Restricting Usage of the Quick Menu
You can set restrictions on the use of Personal buttons and Shared buttons. You can also set whether the Personal buttons or Shared buttons are to be displayed first when you display the Quick Menu. Logging into the Machine
1
Press to display the Quick Menu, and press .
2
Press <Restrict Quick Menu Use>.
When the login screen is displayed, log in as the administrator.
3
Set the usage restrictions.
<Register Shared Buttons>
If you set it to <On>, all users can register/edit Shared buttons. If you set it to <Off>, these operations cannot be made unless the user is logged in as the administrator.
<Use Personal Button>
If you set it to <On>, users who logged into the machine can use Personal buttons. If you set it to <Off>, Personal buttons cannot be used.
<Authentication Default Screen>
You can select whether the Personal buttons or Shared buttons are to be displayed first after a logged-in user displays the Quick Menu when both types of buttons are available.
4
Press <OK>.
1A94-030
