Creating a Shortcut for a Frequently Used Function
You can create a shortcut button for the functions on the Main Menu. Use this button to access a different function without returning to the Main Menu. To create a shortcut, log in with administrator privileges.
Logging into the Machine
1
Press
on the Main Menu.
<Main Menu> Screen
2
Press <Shortcut Button Settings>.
3
Select a number for the shortcut to be created.
4
Select the function you want to create a shortcut for.
Select the function from the list. You can check the position of the shortcut selected and the function assigned to it in the preview screen on the left of the list.
If you do not use shortcuts, select <Unassigned> from the list.
5
Press <OK>.
