Using the Touch Panel Display
The display of the machine is a touch panel that can be operated by touching directly with your fingers. The screen is used not only for basic functions such as copying and scanning, but also to display various settings, text input, communication status and error messages. In this manual, however, "touch" is indicated as "press."
Do not press the touch panel display too hard. Doing so may break the touch panel display.
Do not use an object with a sharp end, such as a mechanical pencil or ballpoint pen. Doing so may scratch the surface of the touch panel display or break it.
Peel off the protective film from the touch panel display before use.
You can customize menus and rearrange frequently used buttons for easier access. You can also combine multiple settings into one button to simplify operations. Customizing the Touch Panel Display
Adjust the brightness of the touch panel display
When it is difficult to see the touch panel display, adjust the brightness using the dial or key on the control panel. Press <+> to increase the brightness of the touch panel display, or <-> to decrease it.
1A94-01X
