Output tray
Front cover
Buffer Pass Unit
For information on the paper sizes that can be used for Staple, see Specifications.
To replace the staple cartridge of the stapler unit, see Replacing the Staples (Optional).
For how to clear a paper jam or a staple jam, see Clearing Paper Jams and Clearing Staple Jams (Optional).
Once the output tray reaches its stacking limit while going down or reaches the lower end of travel, printing is suspended. Remove all of the output paper from the tray to resume printing.
Collate and groupIf you select <Offset> in combination with the collate or group function, each printout group is shifted.
StaplersWhen you are using the Staple mode, do not remove the stack of paper from the output tray during the job. Remove the stack of paper when the job has been completed.
If the <Load staples into the stapler unit.> message appears, almost all of the staples have been used. To proceed, replace the staple cartridge.
