Interface
10Base-T/100Base-TX/1000Base-T (RJ-45)
Protocol Supported
TCP/IP
Frame type: Ethernet II
Print applications: LPD/Raw/IPP/IPPS/FTP/WSD/SMB/Mopria/Google Cloud Print/AirPrint/Windows10 Mobile Print
AppleTalk
Frame type: Ethernet SNAP
Print application: PAP (Printer Access Protocol)
Standard
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Transmission Scheme
IEEE 802.11b (Modulation system: DS-SS)
IEEE 802.11g (Modulation system: OFDM method)
IEEE 802.11n (Modulation system: OFDM method)
Frequency Range
2,412 to 2,462 GHz
Maximum Radio-Frequency Power Transmitte
18.21 dBm
Security (encryption method)
Infrastructure Mode
128 (104)/64 (40) bit WEP
WPA-PSK (TKIP/AES-CCMP)
WPA2-PSK (TKIP/AES-CCMP)
Access Point Mode
WPA2-PSK (AES-CCMP)
Connection Method
WPS (Wi-Fi Protected Setup), Manual setup
