Paper Sizes
Max:
8 1/2" x 14" (216 x 355.6 mm)
Min:
3 7/8" x 5 7/8" (98 x 148 mm)
Paper Weight
16 lb bond to 80 lb cover (60 to 220 g/m²)
Paper Type
All the paper that can be fed
Capacity Per Tray
No finishing set, Collate, and Collate + Offset and Group + Offset mode:
500 sheets (or 2 7/8" (73.5 mm) in height)
Staple mode:
500 sheets/20 sets (or 2 7/8" (73.5 mm) in height)
Staple
Max. Stapling Capacity:
30 sheets
Available Staple Size:
A4, B5, LGL, LTR, EXEC and 16K
Dimensions
(W x D x H) |
23 1/4" x 18 1/8" x 11 7/8" (589 x 459 x 301 mm)
Weight
Approximately 30.9 lb (14 kg)
Maximum Occupancy Space Including the Main Unit
(W x D)
55 3/8" x 25 5/8" (1,407 x 651 mm) (when the multi-purpose tray is extended)
