Using the Files in the Mail Box on Job Hold
You can move or copy documents saved in a temporary storage space (Mail Box) to the Job Hold saving area. For example, you can use the scanned document saved in Mail Box after moving/copying it.
1
Press <Access Stored Files> on the Main Menu.
<Main Menu> Screen
2
Press<Mail Box>.
3
Select a box and then files.
Editing Files in the Mail Box
4
Press <Edit File>
<Move/Duplicate>
<Hold>.
When copying instead of moving, press <Duplicate Files>.
5
Press <Start Moving/Duplic.>.
The document is moved/copied to the Job Hold saving area from Mail Box, you can use it as a print job for Job Hold.
The file without the printing settings cannot be moved or copied.
You may not be able to move/copy the file which was edited on the Mail Box.
