For information on paper sizes and types for each paper source, see "Available Paper."
Name
Canon imageRUNNER ADVANCE C5560i/C5550i/C5540i/C5535i
Type
Desktop
Color Supported
Full Color
Resolution for Reading
600 x 600 dpi
Resolution for Writing
1,200 x 1,200 dpi
Number of Tones
256
Acceptable Originals
Up to 11 3/4" x 17" (297 x 431.8 mm): Sheet, book, three dimensional objects (up to 4.4 lb (2 kg))
Copy Size
Paper SizesMax: 12 5/8" x 18" (320 x 457.2 mm)*1
Min: 3 7/8" x 5 1/2" (98 x 139.7 mm)*1
MarginTop: 3/16" (4.0 mm)
Left and Right: 1/8" (2.5 mm)
Bottom: 1/8" (2.5 mm)
Paper WeightPaper Drawer: 14 lb bond to 140 lb index (52 to 256 g/m2)
Multi-Purpose Tray: 14 lb bond to 110 lb cover (52 to 300 g/m2)
Paper Type
Warm-Up Time
After Powering ON
30 seconds*2
Returning from the Sleep mode
10 seconds*3
First Copy Time
imageRUNNER ADVANCE C5560iFull Color: 4.5 seconds
Black-and-White: 2.9 seconds
imageRUNNER ADVANCE C5550iFull Color: 5.2 seconds
Black-and-White: 3.5 seconds
imageRUNNER ADVANCE C5540iFull Color: 6.1 seconds
Black-and-White: 4.1 seconds
imageRUNNER ADVANCE C5535iFull Color: 7.4 seconds
Black-and-White: 4.9 seconds
Copy Speed*4
(sheet/minute)
(Plain LTR, 100%)
imageRUNNER ADVANCE C5560iFull Color: 60
Black-and-White: 60
imageRUNNER ADVANCE C5550iFull Color: 50
Black-and-White: 50
imageRUNNER ADVANCE C5540iFull Color: 40
Black-and-White: 40
imageRUNNER ADVANCE C5535iFull Color: 35
Black-and-White: 35
Magnification
Regular Paper SizeSame Ratio: Direct±0.5%
Enlargement: 121 %, 129 %, 200 %, 400 %
Reduction: 78 %, 73 %, 64 %, 50%, 25%
Zoom25% to 400% (in 1% increments)
Paper Feeding System/Capacity
Paper Drawer550 sheets x 2 (21 lb bond (80 g/m2))
680 sheets x 2 (17 lb bond (64 g/m2))
Multi-Purpose Tray100 sheets (21 lb bond (80 g/m2))
120 sheets (17 lb bond (64 g/m2))
Multiple Copies
999 sheets
Power Source
imageRUNNER ADVANCE C5560i/C5550i:120 - 127 V AC, 60 Hz, 11.5 A
imageRUNNER ADVANCE C5540i/C5535i:120 - 127 V AC, 60 Hz, 10 A
Maximum Power Consumption
1.8 kW or less
Dimensions
(W x D x H)
24 3/8" x 29 1/4" x 37 3/8" (620 x 742 x 950 mm)
Weight
(Toner bottle included)
Approximately 315.3 lb (143 kg)
Installation Space
(W x D)
37 1/8" x 29 1/4" (943 x 742 mm (when the multi-purpose tray is extended))
Memory Capacity
RAM: 2 GB
HD:
Standard: 250 GB
Maximum: 1 TB*5
Inner Tray Capacity
250 sheets (21 lb bond (80 g/m2))*6
