Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Receiving I-Fax Documents » Setting the Memory Lock Mode
08JK-14E
You can set to store received I-fax documents in the Memory RX Inbox without printing them. You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
If you set [Use I-Fax Memory Lock] to 'On', you can set <I-Fax Memory Lock> for the Memory RX Inbox to 'On' or 'Off' as necessary. (See "Specifying the Fax/I-Fax Inbox Settings" and "Receiving Files Through Fax or I-Fax.")
You cannot store received documents in memory in the cases below. (These numbers may vary depending on the remaining capacity of the hard disk.)
When a total of 1,500 files are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 6,000 pages of documents are stored in the Mail Box and Fax/I-Fax Inbox
To receive documents in memory, you must first set [Use I-Fax Memory Lock] to 'On' in [Set Fax/I-Fax Inbox] in [Common Settings] in [Receive/Forward] in [Function Settings] (Settings/Registration). (See "Specifying the Fax/I-Fax Inbox Settings.")
