Setting the Printer Options
07SE-195
Before printing, you need to set up the printer configuration in order to use the printer options (such as paper feed options, paper output options, etc.) attached to and installed in the machine. When using the printer driver for the first time, or changing the printer options, set up the printer configuration in the driver.
If the machine is connected by bidirectional communication, the options are set automatically when you verify the printer information. If the machine is connected by unidirectional communication, you must set the options manually.
