(Settings/Registration).
to scroll to the desired setting.|
[Restrict URL Entry]:
Select whether to restrict URL entry. If you set this setting to 'On', you cannot make entries in the text entry field.
[Restrict Home Page Edit]:
Select whether to restrict the editing of the home page. If you set this setting to 'On', you cannot make URL entries on the home page screen. Also, you cannot set the current page as the home page.
[Rstrct History Display]:
Select whether to restrict the display of the URL history.
[ID/User with History]:
Select whether to display the Department ID or User Name on the Details screen of the URL history list.
[Hide Buttons in Toolbar]:
Select whether to display the buttons in the toolbar on the home screen. If you set this setting to 'On', the buttons are not displayed.
[Hide Address in Toolbar]:
Select whether to display the address in the toolbar on the home screen. If you set this setting to 'On', the address is not displayed. In addition, you can no longer switch between display and hide on the Web Access screen.
[Full Screen]:
Select whether to enlarge the display to maximum as a default. However, if you set this setting to 'On', the display text entry field setting is set to 'Off'.
[Hide Web Access Button]:
Select whether to display [Web Access] button on the Main Menu screen.
The default settings are:
Restrict URL Entry: Off
Restrict Favorites: Off
Restrict Home Page Edit: Off
Rstrct History Display: Off
ID/User with History: Off
Full Screen: Off
Hide Buttons in Toolbar: Off
Hide Address in Toolbar: Off
Hide Web Access Button: Off
