Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Setting the Box PIN to 7 Digits/Restricting Access
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Authentication Method Settings for Sending Operations » Specifying Authentication Method for LDAP Server
07SE-1YC
You can specify the authentication method for accessing an LDAP server.
Select the authentication information used for accessing an LDAP server.
Press [Function Settings] → [Common] → [Set Authentication Method].
Press [Info. Used for LDAP Server Authentication].
4.
Select information used for LDAP server authentication.
Details of each item are shown below:
[Device Settings]:
Uses the authentication information set in [Register LDAP Server]. (See "Registering an LDAP Server.") Further settings are not required for every user.
[Device Login Auth. Info.]:
Uses the authentication information used for logging in to the machine. Further settings are not required for every user.
This setting is available under the following conditions
When using the same authentication information for logging in to the machine and accessing the LDAP server
When using a login service which supports Integrated Authentication*
* For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
When Integrated Authentication is not disabled
[Regist. Info. for Each User]:
Uses the authentication information registered by each user of an LDAP server. Further settings are required for each user.
5.
Press [OK].
Settings for Each User
The following settings are required to use different authentication information for each user. Each user is required to register LDAP server and authentication information for accessing the LDAP server by following the procedures below.
Log in to the machine.
Press [Main Menu] → [Scan and Send] → .
Press [Register/Edit Info. for Each User].
You can register authentication information for each user from  on the [Scan and Send] Basic Features screen, the [Fax] Basic Features screen, and the [Fax/I-Fax Inbox] Send screen.
4.
Press [LDAP Server Authentication Information].
5.
Select the server to register authentication information.
6.
Enter the user name and password used for LDAP Server authentication → press [OK].
