Top » Remote UI » System Requirements
System Requirements
07SE-1RR
The system requirements for the Remote UI are as follows:
Windows
OS (Operating System)
Microsoft Windows XP
Microsoft Windows Vista
Microsoft Windows 7
Web Browser
Microsoft Internet Explorer 7, or later
Macintosh
Mac OS 10.3, or later
Web Browser
Safari 1.3.2, or later
Available Web browsers may be limited depending on the login services for the MEAP function you are using. For instructions on how to use the login services, see "Overview of Login Services."
The appearance of the Remote UI screens may vary, depending on the type and version of the Web browser that you are using.
This machine is compliant with IPv6 addresses. To access IPv6 addresses, your environment must be compliant with IPv6.
No Web server or software other than that described above is required. (There is a Web server inside the machine.)
