You can only perform a WSD scan under the following conditions:
If [Scanner] is not displayed on the Main Menu screen, press [Show All].
After setting the machine to online, if the operation conflicts with other operations from scan driver, the earlier operation will be received.
You cannot scan 2-sided originals even if you are using a feeder. Place 1-sided originals.
The available scanning size is LTR. For example, if you set 11" x 17" originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
(Start) on a computer → [All Programs] → [Windows Fax and Scan].
If [Windows Fax and Scan] is not displayed in Windows 7, follow the procedures below.
For information on functions of the Windows operating system, see the manual provided with the operating system, or contact Microsoft.
[Profile]:
If you scan text originals, select [Document], or select [Photo] for scanning photos.
[Source]:
If you are using a feeder, select [Feeder (Scan one side)], or select [Flatbed] if you are using the platen glass.
[Paper size]:
Select LTR.
[Color format:]
[Color] is set.
[File type]:
Select from BMP, JPEG, PNG, and TIFF.
[Resolution]:
"300" is set.
Scanned files are stored in [Scanned Documents] folder in [Documents].
If you click [Preview], the scanned file is displayed, but it is not stored in a computer.
