Category Top
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Print Quality
Layout
Auto Error Skip
Secure Print Delete Time
Timeout
Print After Completing RIP
Finishing
Booklet
Saddle Stitch
Creep Correction
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Color Mode
Gradation Settings
Compressed Image Output
Initialize
UFR II Settings
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
CMS (Matching) Selection
CMS (Matching)/Gamma
Gamma Correction
Paper Save
Advanced Smoothing
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code (Symbol Set)
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
RGB Source Profile
Output Profile
Matching Method
Gray Compensation
Gamma Correction
Advanced Smoothing
PS Settings
Job Timeout
Print PS Errors
Pure Black Text
Black Overprint
RGB Source Profile
CMYK Simulation Profile
Use Grayscale Profile
Output Profile
Matching Method
RGB Pure Black Process
CMYK Pure Black Process
Halftones
Brightness
Composite Overprint
Advanced Smoothing
Grayscale Conversion
Imaging Settings
Image Orientation
Zoom
Print Position
Show Warnings
Enlarge Print Area
ICC Profile Settings
Photo Correct (Color Only)
Halftones
Gray Compensation
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Pure Black Text
Black Overprint
RGB Source Profile
Output Profile
Matching Method
Halftones
Brightness
Composite Overprint
Advanced Smoothing
XPS Settings
Matching Mode
Gamma Correction
Photo Correct.(Color Only)
Halftones
Gray Compensation
Advanced Smoothing
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » PDF Settings » Enlarge/Reduce to Fit Size
07SE-1FS
[On], [Off]*
This setting enlarges or reduces the original document to match the printable area of the paper size.
[On]
The document is reduced to a page size that fits the paper size if the page size specified in the PDF file is larger than the printable area of the paper size. Conversely, the original document is enlarged to a page size that fills the paper size if the page size specified in the PDF file is smaller than the printable area of the paper size.
If you specify [Auto] in [Paper Size] using the Remote UI, this setting is not applied.
The PDF file page size is enlarged or reduced with the same ratio for both the length and width.
