Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Overview of Login Services » Default Authentication (Department ID Management)
07SE-1U4
This login service does not use a domain and is operated on the machine. User authentication is performed by setting [Department ID Management] to 'On'. If you set [Department ID Management] to 'Off', user authentication is not performed. When you do not want to use the authentication function, set Default Authentication as the login service.
Default Authentication has two types of users: administrator and general users. The functions of the machine, the Remote UI, and MEAP applications that can be used differ according to the type of user. Which users become administrator or general users depends on whether Department ID Management and System Manager Settings are set, as indicated in the table below.
Administrator
General Users
On
Set
System Manager
Users authenticated with a Department ID and PIN.
Not Set
None
Off
Set
System Manager
Users other than the System Manager
Not Set
All users
None
For information on whether to use Department ID Management and instructions on registering Department IDs/PINs, see "Managing Department IDs" (Remote UI) or "Department ID Management" (Security).
For instructions on specifying System Manager Settings, see "Starting the Remote UI" or "Specifying the System Manager Settings."
