07SE-00Y
All the elements you will ever need in a color digital multitasking machine.
The imageRUNNER ADVANCE C2230/C2225 incorporates a rich array of input and output features that can greatly enhance your efficiency. Equipped with features that meet the needs of document work in a digitized office, the imageRUNNER ADVANCE C2230/C2225 represents the ultimate in color digital multitasking machines.
* Indicates functions, which require an optional product(s).
For information on the optional products required to use each function, see
"Optional Products Required for Each Function."
In addition to normal copying functions, convenient functions, such as "Copy Sample" which helps to avoid copy errors, "Booklet" for making copies into booklets, and "Different Size Originals" for copying originals of different sizes together in one copy operation, are provided to increase your productivity.
You can convert scanned document data to file formats (PDF, JPEG, TIFF, XPS, OOXML) that can be accessed from your computer, and save the data to a network or memory media location. The saved files can also be printed from the machine.
A network location refers to the storage device (Advanced Box) of another imageRUNNER ADVANCE series machine on the network that can be accessed by this machine. Memory media is a storage location that can be used by connecting USB memory to the USB port of the machine.
For more information on Advanced Boxes, see user manuals for other imageRUNNER ADVANCE series machines with Advanced Boxes.
The Send function enables you to send scanned image or document data to file servers, or send it by e-mail or I-fax. A variety of file formats are supported (JPEG, TIFF, PDF, XPS, OOXML), which offer you greater flexibility in accommodating digital workplace environments.
If the Universal Send Advanced Feature Set is installed, you can add Office Open XML (pptx) to the list of supported file formats.
In addition to normal facsimile functions, the machine offers you Super G3 compatibility, which enables you to transmit documents at high speeds, greatly reducing transmission costs as compared to conventional facsimile machines. Scanned documents as well as documents stored in the Memory RX Inbox, and computer data can be sent by facsimile.
You can also send documents to multiple addresses and forward received facsimile to another destination.
Also, the Fax function of a server machine on the same network—another imageRUNNER ADVANCE Series machine with the Remote Fax function—can be shared by using the Remote Fax function.
You can use this machine as a high-speed network printer. Various outputs are also possible, such as 2-sided printing and page alignment.
If the PS Printer Kit is activated, you can use this machine as the postscript printer with the Adobe PostScript3 software.
You can control functions, such as confirming the status of the machine, and job operations, all from your computer's Web browser.
The MEAP (Multifunctional Embedded Application Platform) incorporated in the machine enables you to install applications to expand the functions of the machine.
Scanning Documents into Your Computer (See
"Scanner.")
The Network Scan function enables you to use the imageRUNNER ADVANCE C2230/C2225 as a conventional scanner. You can scan a document using the machine, and read the data in an application you are using on your computer. You can scan images of up to 11" x 17" in size at a resolution of 600 x 600 dpi.
You can specify various settings of the machine connected to a network when using utility software. You can specify initial settings, confirm the status of the machine, and manage documents.
