Text/Photo Priority in a Black-and-White Original
07SE-07R
You can set he text/photo priority when the Automatic Color Selection mode detects that the original is in black-and-white.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Print Settings].
Press [Text/Photo Priority When ACS Is Set to Black].
4.
Specify the following setting → press [OK].
Details of each item are shown below.
[Text Priority]:
The job is processed by giving priority to the text elements on the original.
[Photo Priority]:
The job is processed by giving priority to the photographic elements on the original.
If you select [Text Priority] and the Automatic Color Selection mode detects that the original is in black-and-white, the original is processed as if [Text] is selected as the original type setting, even if you select an original type mode other than [Text].
