This function is only valid when operating Copy function.
To use this function, set [Consider Color] for [Copy] to 'On' in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration). (See "Enabling Paper Drawer Auto Selection.")
(Settings/Registration).|
[Color]:
Paper sources with [Color] setting are used if you select [Auto (Color/Black)], [Full Color], [Single Color], or [Two Colors] in [Select Color] when copying.
[Black]:
Paper sources with [Black] setting are used if you select [Black] in [Select Color] when copying.
In the following cases, the paper source which is set to [Color] is automatically selected regardless of the color mode specified when copying.
When the Merge Job Blocks mode is set
When both the Different Size Originals mode and the Job Build mode is set
