Default Screen (Status Monitor/Cancel)
07SE-05A
You can change the screen that appears when you press [Status Monitor/Cancel].
Press
(Settings/Registration).
Press [Preferences] → [Display Settings] → [Default Screen (Status Monitor/Cancel)].
Specify the settings → press [OK].
[Fax] is displayed only if the fax board is installed.
If you select [Copy/Print], [Send], or [Receive], you can set the type of job that is displayed.
If you select [Consumables], you cannot select [Job Status] or [Log].
If you set [Copy/Print], [Job Status], [Print] as the Default Screen (Status Monitor/Cancel):
If you set [Send], [Job Status], [Fax] as the Default Screen (Status Monitor/Cancel):
