e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
System Requirements
Before Using the Network Scanner
Installation
Selecting the Scanner
Scanning Fundamentals
Switching the Scanner Online and Offline
Scanning from the Platen Glass
Scanning from the Feeder
Viewing the Online Help
Scanning Originals with Correct Orientation
Scanning Different Sized Originals Together
Specifying the Scanning Area
Department ID Management
Setting a Department ID and PIN Beforehand
Entering the Department ID and PIN When You Scan
Questions & Answers
WSD Scan
Overview of This Function
System Requirements
Before Using the WSD Scan
Scan Features of the WSD Scan
Send Features of the WSD Scan
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Scanner
WSD Scan
System Requirements
System Requirements
08KE-1CA
To use the WSD Scan functions, a computer equipped with Windows 7 SP1 or Windows Server 2008 R2 SP1 is required.
Back to Top
