Registering a Personal Button/Shared Button
The number of Personal and Shared buttons that can be registered is as follows:
Personal button: Each user can register a maximum of 8 buttons (maximum total of 1,600 buttons per machine)
Shared button: A maximum of 8 buttons per machine
Select the store location to register.
Press .
Press [Register to Quick Menu].
4.
Select [Personal] or [Shared] → select the button you want to register → press [Next].
5.
Enter a button name and comment.
Press [Name] → enter a name → press [OK].
Press [Comment] → enter a comment → press [OK].
6.
Press [OK] → [Close].
If you want to change the name or comment, press [Rename].
The number of Personal buttons that can be registered may be fewer than the maximum, depending on the memory usage of the Quick Menu function.
For instructions on using a Personal button/Shared button, see "Recalling a Personal Button/Shared Button."
If authentication is not set, the Personal buttons are not displayed.
» Quick Menu » Using the Quick Menu from the Machine » Registering a Personal Button/Shared Button
0UKW-0AR
