Registering to Quick Menu
You can add frequently viewed Web pages to the Quick Menu. The Web pages registered to the Quick Menu are displayed as buttons on the Quick Menu screen. By adding a Web page to the Quick Menu, you can easily access the Web page.
Press [Web Access].
Call up the Web page to add to Favorites → press [Favorites].
Press [Register to Quick Menu].
4.
Select the button to register→ press [Next].
5.
Enter a button name and comment.
Press [Name] → enter a name → press [OK].
Press [Comment] → enter a comment → press [OK].
6.
Press [OK] → [Close].
If you want to change the name or comment, press [Rename].
The number of Personal buttons that can be registered may be less than the maximum, depending on the memory usage of the Quick Menu function.
For instructions on using a Personal button/Shared button, see "Recalling a Personal Button/Shared Button."
If authentication is not set, the Personal buttons are not displayed.
» Web Access » Using Favorites » Registering to Quick Menu
0R9W-178
