You can select multiple entries by holding down [SHIFT] or [CTRL] on the keyboard and clicking each entry that you want to select.
You can register up to 3,000 group entries.
To delete a registered item from the address book, select the item from the address book list and click [Delete].
You cannot access or edit the address book if you do not have access permission to the destination folder of the address book. If this is the case, log on as a user having access permission to the folder, or click [Specify a Folder] in the [Edit Address Book] tab, and change the destination folder of the address book to a folder that you have write permission for (see "Changing the Address Book Export Destination").
You can also edit previously registered group destination information. For more information, click [Help] in the bottom right-hand corner of the fax driver window to view Help.
The display may vary according to the operating system and fax driver version you are using.
