If you have registered frequently used settings as "profiles," you can apply the settings by simply selecting them from the [Profile] list.
Display the fax driver screen from the [Control Panel].
See "Specifying the Default Fax Settings" on how to display the fax driver screen.
Specify the desired settings in the [Select Destination], [Cover Sheet] tabs → click [Add].
Set [Name] and [Icon] → click [OK].
Enter additional information in [Comment] if necessary.
For information on selecting a profile when sending a fax, see "Selecting a Profile for Faxing."
To edit or delete a profile, click [Edit] at the right of [Profile] in the [Sending Settings], [Cover Sheet], or [Special] tab.
The display may vary according to the operating system and fax driver version you are using.
» Fax » Sending a Fax from a Computer (Windows) » Faxing Fundamentals » Registering a Profile for Faxing
0R9W-0X0
