Top » Scanner » WSD Scan » Send Features of the WSD Scan
0R9W-193
This section describes how to use the send function of the WSD Scan.
You can only perform a WSD scan under the following conditions:
Paper size:
LTR
Color mode:
Color
Resolutions:
300 dpi (fixed setting)
File format:
BMP, JPEG, PNG, TIFF
Place your originals.
You cannot scan 2-sided originals even if you are using a feeder. Scan each side of a two-sided original separately.
The available scanning size is LTR. For example, if you set 11" x 17" originals, only LTR size is scanned.
For instructions on placing originals, see "Placing Originals."
Press [WSD Scan].
Select the destination.
Computers in the same domain in which the driver for the WSD Scan function is installed are listed. Select the desired destination.
4.
Press [Start].
If the destination [Scan to "computer name"] is selected:
A screen prompting you to select a program appears on the computer screen. Scanning is complete after selecting the program.
If the destination other than [Scan to "computer name"] is selected:
Windows Explorer starts and a scanned file is displayed on the computer screen.
Up to 40 destinations are displayed.
You cannot use [Send for OCR to "computer name"] when selecting the destination. If you want to use the OCR function, see "Searchable PDF/OOXML."
