Flow of Settings for Operating with Local Device Authentication
This section describes the flow of settings for operating the Access Management System with local device authentication.
The steps that are required differ according to the system configuration. When operating with server authentication, see "Flow of Settings for Operating with Server Authentication."
1. Preparing the Device and Network Environment
Set the network environment and date/time settings, etc., of all devices to operate with the Access Management System, and register a System Manager ID in each device.
2. Enabling the AMS
Enable the AMS on all devices to operate with the Access Management System.
For more information, see the instruction manuals of the device.
3. Starting User Authentication
Start User Authentication in all devices that support AMS.
4. Setting Security
Specify the security related settings, such as passwords and lockout policies.
5. Specifying the Preferences of the Devices
Specify the preferences of all devices that support AMS.
6.Managing Roles
Create/edit the custom roles and edit the guest roles, as necessary. Since roles can be imported/exported, they can be used in multiple devices.
7.Managing Users
Register/edit the users that will use the device. Also register role names to apply to the user information. If a role name is not registered to a user, the role set in [Default Role] in the preferences of the devices is applied to that user. Since user information can be imported/exported, it can be used in multiple devices.
When using the Department ID Management function in conjunction with the Access Management System, start the Department ID Management function and register the Department IDs after the Access Management System setup (the above operations) is complete. For information on the Department ID Management function, see the instruction manuals of the device.
When using the Department ID Management function in conjunction with the Access Management System, the [Department ID] and [PIN] registered in the user information must match the [Dept. ID] and [PIN] registered in Department ID Management. If the information in Department ID Management changes due to device information delivery settings, etc., change the user information in accordance.
To restrict printing from computers, it is necessary to add the AMS Printer Driver Add-in to the printer drivers installed in the computers, after the above operations are complete. For more information, see "Setting Up the Client Computers."
» Setting Up the Access Management System » Flow of Settings for Operating with Local Device Authentication
