Top » Optional Products/Software » Software » Workflow Composer
Workflow Composer
0C1Y-046
Workflow Composer is an option that increases the efficiency of routine operations that use multiple functions of machines. By creating and registering combinations of functions that are frequently used on the machine, you can repeatedly reuse the same combination of functions.
For example, reducing the original, converting the scanned data into a PDF file, and then e-mailing that PDF can all be performed by pushing just one button.
