Specifying Send/Fax Security Settings
0C1Y-1WK
When entering a fax destination manually, there is a potential for the information to be leaked if the fax is mistakenly sent to the wrong destination.
Also, there is a possibility that data may be intercepted during the sending process by external users with ill intent.
By specifying the applicable security settings on your imageRUNNER ADVANCE machine, you can help minimize the risk of information leakage when sending data.
This section describes procedures for the settings below.
The screens may differ, depending on the model of the machine and on attached optional products.
Setting the Address Book PIN
You can set a PIN for the Address Book, which is used when sending faxes and scanning. By setting a PIN, you can restrict the registering, editing, adding, and erasing of destinations. You can enter up to seven digits for the Address Book PIN.
Limiting New Destinations
This mode restricts sending to registered destinations only. Setting this mode in combination with the Address Book PIN enables you to strengthen the security for sending. Sending is only allowed in the following cases when this mode is set:
If you specify a destination stored in the Address Book
If you specify a destination via an LDAP Server
If you specify a destination by pressing a one-touch button
If you recall a destination stored in [Favorite Settings]
If you select [Send to Myself]
You can turn the limits On or Off for each send function (Fax, E-Mail, I-Fax, File Server).
You cannot enter new destinations for a restricted function.
Managing Address Book Access Numbers
This mode enables you to assign access numbers to each destination so that when you enter an access number, only the corresponding destination is displayed. By managing the access numbers and combining this mode with Limit New Destinations, you can limit the destinations available to each user.
Confirming Entered Fax Numbers
This mode requires you to enter a fax number and confirm the number (enter the number a second time) to prevent misdialing.
Prohibiting Sending from the Fax Driver
This mode enables you to set the machine to prohibit sending from the fax driver.
By combining this mode with the management functions of the machine, you can help prevent unauthorized sending.
Setting the MAC Address Filter
The MAC Address Filter identifies the sender and regulates transmission.
A MAC Address is set for the machine receiving communications. A MAC Address is a unique network interface ID number for computers and network machines.
Access is restricted to machines with an authorized MAC address. A MAC address does not change even if the IP address is changed, enabling you to securely transmit data.
Specifying the TX Destination Domain
This mode enables you to restrict the domains where e-mails can be sent.
If you restrict the domains for sending, you can send documents only to destinations that belong to the specified domains. In turn, this helps prevent information leakage.
You can set a password for opening a PDF file or encrypt the PDF file itself for sending. If you set a password for a PDF file, only recipients who enter the correct password can open, edit, or print the file. Also, you can grant editing/operating privileges according to the sensitivity of the information (optional kit required).
Required Condition
You are logged in as the administrator.
You can perform this procedure using the touch panel display or the Remote UI.
Access the Remote UI → click [Settings/Registration] → [Set Destination] → [Address Book PIN].
Select [Set Address Book PIN] → enter up to seven digits for <Address Book PIN> and <Confirm>.
If you do not enter a PIN, you cannot display the Address Book from the Remote UI.
You cannot edit the Address Book from the machine.
Using the Touch Panel Display
Press
(Settings/Registration) → [Set Destination] → [Address Book PIN].
Press [Set].
Enter PIN and Confirm → press [OK] → [OK].
Access the Remote UI → click [Settings/Registration] → [Send] → [Limit New Destination].
Select the functions for which you want to limit new destinations.
Press
(Settings/Registration) → [Function Settings] → [Send] → [Common Settings] → [Limit New Destinations].
Select the types of destinations to limit → press [On] → [OK].
Access the Remote UI → click [Settings/Registration] → [Set Destination] → [Manage Address Book Access Numbers].
Select [Manage Address Book Access Numbers].
Press
(Settings/Registration) → [Set Destination] → [Manage Address Book Access Numbers].
Press [On] → [OK].
Access the Remote UI → click [Settings/Registration] → [Send] → [Confirm Entered Fax Number].
Select [Confirm Entered Fax Number].
Press
(Settings/Registration) → [Function Settings] → [Send] → [Fax Settings] → [Confirm Entered Fax Number].
Press [On] → [OK].
A confirmation screen will be displayed each time a fax number is entered.
Access the Remote UI → click [Settings/Registration] → [Send] → [Allow Fax Driver TX].
Deselect [Allow Fax Driver TX].
Press
(Settings/Registration) → [Function Settings] → [Send] → [Fax Settings] → [Allow Fax Driver TX].
Press [Off] → [OK].
Press
(Settings/Registration) → [Preferences] → [Network] → [Firewall Settings] → [MAC Address Filter].
Specify the settings as necessary.
Specify the necessary settings for [Limit New Destination].
These settings can also be specified from the control panel of your machine.
Press
(Settings/Registration) → [Function Settings] → [Send] → [E-mail/I-Fax Settings] → [Restrict TX Destination Domain].
Specify the necessary settings → press [OK].
Place your originals on the platen glass or in the feeder → press [Scan and Send] on the Main Menu screen.
If the Main Menu screen is not displayed, press [Main Menu].
Specify the destination → press the File Format button → [PDF] → [Set Details].
Press [Encrypt].
4.
Specify the desired settings → press [OK].
If you select [Password Required to Change Permiss.] → press [Set Details] → set the encryption level and other settings.
The settings that can be specified differ depending on the encryption level (High 128-bit/Low 40-bit).
The settings available for each encryption level are described in the table below.
Comparison of Settings by Encryption Level
Encryption Level
Acrobat 3.0 or Later/40-bit RC4
Acrobat 6.0 or Later/128-bit RC4
Acrobat 7.0 or Later/128-bit AES
Acrobat 9.0 or Equivalent/256-bit AES
Acrobat 10.0 or Equivalent/256-bit AES
Version for Viewing
Adobe Acrobat 3.0 or later
Adobe Acrobat 6.0 or later
Adobe Acrobat 7.0 or later
Adobe Acrobat 9.0 or later
Adobe Acrobat 10.0 or later
Allow Printing
Do Not Allow/Allow
Do Not Allow/Allow (Low Res. Only)/Allow
Allow Changes
Do Not Allow
Commenting and Signature Field Signing
Change but Add Comments/Extract Pgs.
Changes but Extract Pages
Do Not Allow
Insert, Delete, or Rotate Pages
Enable Accessibility, Copy, Extraction of Image/Text
If [Password Required to Change Permiss.] is set to 'On'.
Enable Copying and Extraction of Images/Text
Enable Access for the Visually Impaired
You can perform SSL communication which encrypts your data transmissions. Doing so helps prevent data interception, theft, and modification.
SSL Encrypted Communication is a send/receive protocol that encrypts data on the Internet. This protocol is widely used to encrypt data on the Internet such as WWW and FTP, which enables confidential information including credit card numbers and trade secrets to be securely transmitted.
You can also transmit files using WebDAV. WebDAV enables you to share files via an Internet server. If the server supports SSL (HTTPS), all transmissions over the server are encrypted, making file sharing more secure and versatile.
