Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Security
System Management
Copy Security with Forced Secure Watermark
Secured Print
Data Security
Specifying Send/Fax Security Settings
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Department ID Management
0C1Y-1W8
What Is Department ID Management?
Department ID Management enables you to keep track of the copy and print totals for each department.
You can set an ID and PIN for each department, and manage the machine use for each ID.
Department ID Management is a function limited to users with a registered ID and PIN, and automatically records their use of the machine. You must enter a valid ID and PIN when copying or printing, and only one ID can be logged in at a time. This results in an accurate record of machine use for each ID.
If you install a Card Reader, you can use a card for authentication instead of entering an ID.
You can manage the number of pages used for each card, in the same way as an ID.
You can verify the totals for each ID from the machine's touch panel display, on the Print List, or via the Remote UI.
The Department ID Management and MG Counter totals may differ.
Authentication by card is only valid for copying. You cannot use a card to manage printing totals.
Features of Department ID Management
Only users with a registered ID and password can use this function.
You can manage copy/print totals for each ID.
You can set output restrictions for each ID.
Benefits of Using Department ID Management
By restricting an ID to one department, you can prevent users from other departments from using the ID.
Totals for each ID can be used by the administrator as a guide when determining the budget. By setting an ID for each user, you can keep track of the number of pages printed by each individual.
By setting a page limit (maximum number of prints) for each department, you can promote the prevention of waste copying and printing.
Helps minimize paper use, making it beneficial for obtaining ISO14001 certification.
