Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Security
System Management
Copy Security with Forced Secure Watermark
Secured Print
Data Security
Specifying Send/Fax Security Settings
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Fax » Forwarding to a Mobile Computing Device
0C1Y-1UY
You can forward faxes via e-mail to a mobile computing device (laptop) with e-mail access, enabling the recipient to view the file on their mobile device while out of the office.
A total of 256 e-mail addresses, shared computer folders and other forwarding destinations can be registered, and you can perform a sequential broadcast transmission to all destinations (Universal Send). This enables users both in and out of the office to view the same document, on desktop computers and laptops respectively.
If you receive an urgent fax while out of the office, even if the fax is forwarded, you may have limited opportunities to check your laptop while out of the office and you have no way of knowing precisely when you receive a forwarded fax. However, you can set to receive automatic e-mail notification to your mobile phone when you receive a forwarded fax to your laptop.
By setting a group address as the forwarding destination, you can perform a sequential broadcast transmission.
Number of Destinations Able to Be Registered in the Address Book
Address lists 1 to 10
Total of 1,600 destinations
One-touch buttons
200 destinations
Destinations (incl. group addresses)
Maximum of 1,800 destinations
Each group address
256 destinations
Sequential broadcast transmission
256 destinations
Required Condition
The Send function is available for use.
To forward a fax via e-mail, you must have e-mail access and specify e-mail settings on the machine.
Setting the Forwarding Done Notice
You can set to send a forwarding done notice to a specified e-mail address according to the original sender.
This is useful when you want to prevent nonessential notification.
You can perform this procedure using the touch panel display or the Remote UI.
The screens may differ, depending on the model of the machine and on attached optional products.
Using the Touch Panel Display
Press (Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Forwarding Settings] → [Register] → specify each setting.
Press [Next] → [Forwarding Done Notice] → select a registered e-mail address → press [OK].
When you return to the screen for registering forwarding settings, the [Forwarding Done Notice] button will have changed color indicating that the setting is enabled. Press [OK] to complete the setting.
4.
Select the registered forwarding settings → set [Validate/Invalidate] to 'On'.
The notification e-mail is sent at the same time as the fax is forwarded.
You can set to send a notification e-mail only when a forwarding error occurs.
You can select only one destination for a forwarding done notice. To send to multiple destinations, register the destinations under a single group address.
Forwarding done notices viewed on a mobile phone may have different layouts depending on the model of your phone.
Fax sender information is not included in the notification e-mail. Also, you cannot edit the content of the notification e-mail.
The notification e-mail also includes a link to the folder in which the forwarded document is stored.
It is recommended that you send a test mail prior to use.
Using the Remote UI
These settings can also be specified from the Remote UI.
Access the Remote UI → click [Settings/Registration] → [Receive/Forward] → [Forwarding Settings].
Register forwarding settings via [Add New Conditions]. These settings can also be specified from the Remote UI.
[Enable This Forwarding Condition] is equivalent to the [Validate/Invalidate] button in the forwarding settings screen on your imageRUNNER ADVANCE machine.
Reference Information
Forwarding File Format
You can receive faxes in the following formats:
via Fax/Internet Fax/Intranet Fax
TIFF, PDF, XPS
