Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Security
System Management
Copy Security with Forced Secure Watermark
Secured Print
Data Security
Specifying Send/Fax Security Settings
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals while the Machine is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Digitizing Paper Documents
0C1Y-1U8
Push Scan
The Push Scan function of your imageRUNNER ADVANCE enables you to convert paper documents to digital files and send the files to a shared folder on your computer, as quickly and easily as sending a fax.
This function is also referred to as "SMB Send," as transmitting the digital data uses the SMB (Server Message Block) protocol.
Without the need for a separate delivery server, anyone with access to an imageRUNNER ADVANCE machine and a computer can digitize paper documents with ease.
Benefits of Digitization
Uniform management of information from paper and digital sources
Significant reduction in space required for storage
Reduction in printing costs and conservation of paper resources
Promotion of the reuse and sharing of stored documents.
Features of the Push Scan Function
No need for a separate delivery server
No need for additional software to specify address book settings. Simply use the machine or your computer's Web browser.
Enables you to select a file format for the files you want to send using your imageRUNNER ADVANCE machine.
Network Scan
The Network Scan function enables you to scan an original placed on an imageRUNNER ADVANCE machine using your computer, in the same way as a flatbed scanner.
Benefits of the Network Scan Function
(1)
An abundant selection of file formats.
(You can store scanned data in a format supported by the TWAIN application you are using.)
Using Adobe Acrobat → PDF
Using Imaging → TIFF/JPEG/BMP
Using imageWARE Document Manager → imageRUNNER ADVANCE exclusive file format
(2)
Enables you to specify the scan area when scanning from the platen glass.
(3)
You can adjust the image.
Change the type of original and edit density.
To use the Network Scan function on your imageRUNNER ADVANCE machine, you must first install Color Network ScanGear, included with your machine. The latest version is available for free download from the Canon website.
Compatible OS:
Windows XP/Vista/7/NT4.0/Server 2003/Server 2008
(Mac OS are not supported)
Select Color Network ScanGear as the scanner from a TWAIN compatible application.
The method for selecting Scanner differs depending on the application.
When using imageWARE DocumentManager, select [Scan] from the [Tools] menu.
(1)
Specify Color Mode, Resolution, Original Placement, and various other settings.
(2)
Press the Scan button to start scanning.
