You can enter up to 24 characters for the unit name.
If the unit name is comprised of only ASCII characters, the name is enclosed with double quotation marks (") in the From field on the machine that receives e-mail/I-faxes. If characters other than ASCII characters are used, the unit name is not enclosed with double quotation marks (").
If the Local Device Authentication user authentication system of SSO-H is set as the login service and you are sending an e-mail message:
The e-mail address registered for the user in the Local Device Authentication user authentication system of SSO-H is displayed in the From field on the recipient's machine, instead of the e-mail address registered in the Device Information settings for this machine. (See "Registering/Editing User Data for Local Device Authentication.")
The e-mail address registered in Device Information settings is displayed in the From field on the I-fax recipient's machine. The e-mail address of the registered for the user in the Local Device Authentication user authentication system of SSO-H appears in the Sender field. (See "Registering/Editing User Data for Local Device Authentication.")
If you have set the Server Authentication user authentication system of SSO-H as the login service (including when performing Server Authentication with the 'Server Authentication + Local Device Authentication' user authentication system) and you are sending an e-mail message:
The e-mail address registered for login users on the Server Authentication or imageWARE Accounting Manager is displayed in the From field on the recipient's machine, instead of the e-mail address registered in the Device Information settings for this machine. (See "Registering/Editing User Data for Active Directory Authentication" and "Registering/Editing User Data for LDAP Server Authentication.")
The e-mail address registered in the Device Information settings for this machine is displayed in the From field. The e-mail address registered for login users on the Server Authentication or imageWARE Accounting Manager appears in the Sender field on the recipient's machine. (See "Registering/Editing User Data for Active Directory Authentication" and "Registering/Editing User Data for LDAP Server Authentication.")
If you set [Set Authentication User Destination to Sender] in [Function Settings] (Settings/Registration) to 'On', the e-mail address registered for the login user is displayed as the sender's name in the From field for the recipient, regardless of the login service being used. If you set this mode to 'Off', the address registered in the Device Information settings is displayed instead.
For instructions on registering your machine's e-mail address, see "Registering an E-Mail Address."
